Combining Similar Hierarchies into a Single Hierarchy
Purpose
This tutorial covers how to combine similar hierarchies into a single hierarchy.
Time to Complete
Approximately 20 min.
Overview
With a blender, you can combine similar hierarchies into a single hierarchy. For example, you blend a TotalGeography1 hierarchy in a version used for operational purposes into a TotalGeography2 hierarchy in another version used for budgeting purposes. Both hierarchies have similar nodes, but the TotalGeography2 hierarchy is more detailed in structure than the TotalGeography1 hierarchy.
For this type of blender, you configure the following blender wizard tabs in this manner:
In this tutorial, you combine similar hierarchies into a single hierarchy.
Prerequisites
Before starting this tutorial, you should have access to or have installed Oracle Hyperion Enterprise Performance Management 11.1.2.1.0 and Oracle Hyperion Data Relationship Management, Fusion Edition 11.1.2.1.0.
Reviewing Hierarchies
In this topic, you review the hierarchies that you are going to blend, the TotalGeography hierarchy in the 2010 04 - Production version and the TotalGeography hierarchy in the 2010 05 - Production version. The hierarchies are opened for you.
1.
Begin in the Browse task group. Use the Browse task group to manage versions and hierarchies.
Show Screenshot for Step
2.
Click the TotalGeography - 2010 04 - Production tab.
Under the top node, this hierarchy has four limb nodes: E00, E01, E02, and E05.
3.
Click the TotalGeography - 2010 05 - Production tab.
Under the top node, this hierarchy has two limb nodes (E03 and E04) and one leaf node (E05).
Blending Similar Hierarchies
In this topics, you create a blender that blends the two versions of the TotalGeography hierarchy that you just reviewed.
1.
Right-click the Home tab.
2.
Click Blend from the drop-down menu to navigate to the Blend task group.
Use the Blend task group to create, copy, and delete blenders.
3.
Click the New Blender button.
Use the blender wizard to configure the source, style, filters, properties, and target for your blender. You begin on the Source tab.
4.
Use the Source tab to select the source and target versions for the blender. You can blend all hierarchies from both versions or selected hierarchies from the source version. In this example, you blend all hierarchies from both versions. Perform the following actions on the Source tab:
  • In the Source Version drop-down list, select 2010 04 - Production
  • In the Target Version drop-down list, select 2010 05 - Production
  • Clear the Blend All Hierarchies field because you want to define a hierarchy/top node set for the TotalGeography hierarchies.
    Note: If you select the Blend All Hierarchies field, the Use Profile Defaults For All Hierarchy Sets field is automatically selected.
  • Leave the Use Profile Defaults For All Hierarchy Sets field selected. Use this field to apply the profile default (filters and properties) to all hierarchy/top node sets. If you clear this field, you can later configure it for each hierarchy/top node set.
5.
Click the New button to add a hierarchy/top node set.
Use the Add Blender Hier-Set dialog box to map a hierarchy/top node in the source to a hierarchy/top node in the target.
6.
  • In the Hierarchy drop-down list, select TotalGeogrpahy.
  • Leave theTotalGeography node selected as the source top node.
7.
Click the Target tab.
Perform the following actions on the Target tab:
  • In the Method drop-down list, select Selected. Use this list to indicate whether you want to specify or select a hierarchy and target top node.
  • In the Hierarchy drop-down list, select TotalGeography.
  • In the Nodes section, select TotalGeography as the target top node.
8.
Click OK.
The Source and Target columns display the hierarchy/top node set that you just configured.
9.
Click the Style tab.
Use the Style tab to select structure and property options for your blender.
10.
Perform the following actions on the Style tab:
  • Select the Process Structure option to enable all structural actions on the Filters tab. Actions include inserts, removes, moves, activations, and hierarchy validation assignments.
  • Leave the Allow Hierarchy Creation option cleared. If you do not select this option and hierarchies exist in the source version but not in the target version, then an error occurs.
  • Select the Allow Leaf Promotion option to promote a leaf node in the target version to a limb node. If a node in the source version has children, but its corresponding node in the target version is a leaf node, then this feature enables the blender to promote the node to limb status. The child nodes from the source version are then added under the limb node in the target version.
  • Select the Process Properties option to control whether property values are blended on the Properties tab.
  • Leave the Disable Realtime Validations option cleared to display all real-time validations on the target version in the blender results. This feature is useful when you expect many invalid changes to occur and prefer to analyze those changes later on by using batch validations.
  • Leave the Use the Process Version Validation Assignments option cleared. This feature enables the blender to process version-level validation assignments from the source version to the target version.
11.
Click the Filters tab.
Use the Filters tab to select processing options for the profile default. You can also specify hierarchy overrides, if needed.
12.
Perform the following actions on the Profile Defaults sub-tab of the Filters tab:
  • Leave the Process Inserts option selected to insert any nodes existing only in the source hierarchy into the target hierarchy. If a node being inserted does not exist in the target version, then it will be created by the blender.
  • Clear the Process Removes option that enables the blender to remove nodes that exist only in the target hierarchy. If you select this option, you must select one of the following options for the remove mode:
    Remove—removes the node during blending
    Mark—marks the node for later removal. You also select a remove indicator property that flags the node for removal. Note: An administrator must create this local Boolean property beforehand.
  • Clear the Process Moves option that enables the blender to move nodes that have a different parent in the source version to that parent in the target version.
  • Clear the Process Activations option that enables the blender to process node activations (inactivate and reactivate) from the target version to the source version.
  • Clear the Process Hierarchy Validation Assignments option that enables the blender to process the hierarchy-level validation assignments from the source version to the target version.
13.
Click the Properties tab.
Use the Properties tab to configure default properties to be blended for the blender profile. You can also configure hierarchy overrides, if necessary.
14.
Perform the following actions on the Profile Defaults sub-tab of the Properties tab:
  • In the Property Selection drop-down list, select Selected. Use the Property Selection list to specify whether you want to blend specific properties, no properties, or all properties (excluding properties used for node-level validations and for node access group assignments).
  • In the Property Propagate Mode drop-down list, select Defined. Use the Property Propagate Mode field to specify how a property is populated in the target. You can select one of the following options, which are listed from most used to least used:
    Defined—overwrites the target property value with the source property value for any node where the property is explicitly defined in the source version.
    Difference—overwrites the target property value with the source property value for any node where the source and target property values are different, and regardless of how that property is populated in the target version.
    Force—overwrites the target property value with the source property value for every node in the target, regardless if that property is defined for that node, is inherited, or is derived.
  • Leave the Propagate Property Locks option cleared. This feature enables the blender to blend locks for inherited property values in the source version into the target version.
15.
Click Add to select properties to be propagated.
16.
In the Property drop-down list, select Country.
17.
In the Propagate Mode drop-down list, select Difference.
18.
Click the Update button.
19.
20.
In the Property drop-down list, select Region.
21.
22.
23.
Use the Target tab to define a new version that stores the blender result, set maximum iterations and maximum error values, and configure blender status properties.
24.
  • In the Target Version drop-down list, select Copy to New Version to create a version to store the blended result.
  • In the Name field, enter 2010 06 - Production.
  • Optional. In the Description field, enter a meaningful description of the target version.
  • Leave the Max Iterations field to its default value of 1—The Max Iterations field specifies the maximum number of attempts to reconcile the source and target versions. In this example, one iteration is sufficient because there is no overlap between the blended hierarchies. Conflicts that would require additional iterations are not possible.
  • Leave the Max Errors field to its default value of 10—The Max Errors field sets the maximum number of errors that can occur during processing before the blender stops.
  • Select the Populate Values option to set each configured blender status property to True during processing.
  • For the blender status property named Global Node Changed, select the Node Changed property to store the Boolean value.
25.
Click the Save As button.
26.
In the Save Blender dialog box, perform the following actions:
  • In the Name field, enter TotalGeography Blender.
  • Optional. In the Description field, enter a meaningful description of the new blender.
  • In the Object Access Level drop-down list, leave User selected. The Object Access Level field assigns one of the following access levels:
    • User—Enables only you to run and edit the blender
    • Standard—Enables all users to run the blender, but only users with the Data Manager role can edit it
27.
Click OK. The tab name is displayed as Accounts Entity Blend.
28.
Click the Run button to process the blender.
The blender completed processing without any errors.
29.
Click the << button.
30.
Click Home.
Your blender is listed in the Blend task group.
Viewing the Blender Results
In this topic, you verify the blender results.
1.
Click Browse to navigate to the Browse task group for viewing the blended results.
2.
Click the 2010 06 - Production version to view its hierarchies.
3.
Expand the Entity hierarchy group.
4.
Double-click the TotalGeography hierarchy.
Nodes from both the 2010 04 - Production and 2010 - 05 Production versions are combined into the TotalGeography hierarchy in the 2010 06 - Production version.
5.
Expand the E05 node to view its children.
The E05 node was promoted from a leaf node to a limb node in order to add the descendants from the source hierarchy (TotalGeography hierarchy in the 2010 04 - Production version).
6.
Click the E04_605 node to view its Node Changed property value that you configured in the blender.
7.
Click the Properties button.
Use the Properties tab to view and manage properties for nodes, hierarchies, and versions.
8.
Click the Category drop-down list.
9.
Select Blender Status from the Category drop-down list.
The Node Changed property for the E04_605 node is set to True because the global node's properties were changed by the blend.
Summary
In this tutorial, you have learned how to combine similar hierarchies into a single hierarchy.
Resources
